Apr 30th, 2024, 9:50am
Differential interface (Read 1337 times)
Linus
Guest
Nov 07th, 2005, 11:24pm
Hi All,
I am looking for different topologies integrating a differential interface with the following requirements:
- differential interface with on-chip 50 Ohm termination
- very small power consumption
- the differential signal provides is switched current source with 5mA. both input lines are externally terminated with 50 Ohms to 3.3V.
- the input frequency is 400 MHz
What kind of topology would be the best as the complete system is very jitter sensitive ?
Thanx for the hopefully incomming answers,
Linus
  IP Logged
