May 16th, 2024, 7:23pm
VCO model from the Verilog-AMS section (Read 2533 times)
trond
Glasgow, Scotland
Aug 11th, 2005, 7:12am
I was wondering whether there is a way of modelling the VCO from the AMS section so that it accepts negative voltages and has the lowest output frequency when the input is at its most negative value. I initially changed the switching points for the phase to also take negative values into consideration; however,  then I will end up with the same output frequency for two identical input values, one being positive and one being negative. Can anyone please suggest a way of having a VCO accepting negative input values?
Thanks.
Re: VCO model from the Verilog-AMS section
Reply #1 - Aug 11th, 2005, 9:29pm
Can you post the model you have? It's hard to see why this should be a problem without some idea as to what your model looks like.
Most VCO models tend to work by converting the input voltage to a frequency (gain*V(in)+fc) and then integrating that (using idtmod), and then using this as the phase for sin() or cos(). If modelled like this, negative input voltages wouldn't be a problem - provided that the overall frequency remains positive.
In other words:
inst_freq = gain*V(vin)+fc;
phase = idtmod(inst_freq,0,1);
V(vout) <+ amp*sin(2*`PI*phase);
