May 16th, 2024, 11:20pm
debugging in Verilog AMS (Read 4497 times)
king
Aug 17th, 2005, 8:47pm
Hi everyone!
How do I print the internal variables of a model at DC
simulation in Verilog AMS?
Thanks.
Re: debugging in Verilog AMS
Reply #1 - Aug 18th, 2005, 10:09am
You should be able to use $strobe.
begin: named_block
 real x;
 x = ....
 $strobe("x=", x);
The latest LRM has $debug, which has the same syntax as $strobe, but prints on every iteration of the analog solver; your simulator may or may not support this task yet.
king
Reply #2 - Aug 19th, 2005, 2:09am
thanks geoffrey.
$strobe does not work.
i can only debug during a transient simulation using
`DEBUG_PRINT("x",x)
is this a problem with my simulator?
Reply #3 - Aug 22nd, 2005, 5:27am
$strobe has been in the Verilog-AMS LRM for quite a while, so yes, it is a problem with your simulator.  Having said this, I now have a vague recollection of a different thread where it was determined that a particular simulator did not have this system task, but did have $write.  (There are subtle differences in the behavior $strobe, $write, $display, $monitor, but I think they're not important for an analog simulation.)
I am not familiar with the `DEBUG_PRINT macro; it is not part of the standard.  Perhaps you can look through the header files and find its definition -- which may use $write (or is it $display?).
