Sep 17th, 2024, 6:13am
variable Vth (Read 6142 times)
jason_class
singapore
variable Vth
Aug 19th, 2005, 7:14am
Hello All
Could anyone tell me why cmos circuit with variable Vth is considered an advantage for low power technology?
Kindly advise.
Thank you
best regards
Jason
trond
Glasgow, Scotland
Re: variable Vth
Reply #1 - Aug 19th, 2005, 9:31am
I think the main advantage of using multiple thresholds is that they can achieve low power and high performance while maintaining low leakage current.
As far as I know you could use high threshold transistors to suppress the subthreshold leakage current, while the low threshold transistors could be used to achieve the high performance. But I am not very knowledgeable on that topic.
jason_class
singapore
Re: variable Vth
Reply #2 - Aug 20th, 2005, 1:14am
Hi Svensl
That's right. Thank you
But any idea how cetain parameters is changed or manipulated to get a complex system where we have the Vt varied for certain applicatons?
How would this attempt  complicate the whole system and what is the trade off?
Thank you all
jason
trond
Glasgow, Scotland
Re: variable Vth
Reply #3 - Aug 20th, 2005, 2:26am
I am not sure how to do that. I would have to study papers first in order to get familiar with that topic, such as
"Low Voltage Low Power CMOS Design Techniques for Deep Submicron ICs" by Vivek K. De
http://ieeexplore.ieee.org/iel5/6598/17617/00812579.pdf?tp=&arnumber=812579&isnu...
Maybe someone else from the forum knows.
jason_class
singapore
Re: variable Vth
Reply #4 - Aug 21st, 2005, 5:36am
Yes checking out the paper from you Svensl
Let's see if anyone has any idea
will write back again
jason
ssupin-ma
San Jose, CA
Re: variable Vth
Reply #5 - Aug 22nd, 2005, 4:23pm
Without going into too much detail, lower the supply voltage can reduce the power consumption. And to make a digital gate can recognize the "1" and "0", we need lower Vt MOS device. But the I/O require higher signal level to overcome the environment noise (and parasitics), so we need multi-Vt process as a low power MOS process. That we can keep the core circuit runing with low vt device with low supply voltage, and I/O with high vt devices.
In some advance process (90nm and  beyond) the off leakage current become important. Some circuit will use a medium/high vt device to turn off the supply voltage of part of circuits when we don't using it. And some circuit can story some data from low vt RAM to some high vt RAM and shootdown the low vt RAM when we are not exchange the data. And re-store the data back to low vt RAM when we need high speed operation.
Ssu-Pin Ma (Simon)
Re: variable Vth
Reply #6 - Aug 25th, 2005, 10:44am
Didn't Intel have some report on how they varied the body voltage of a MOS transistor to get its threshold voltage to vary?
jason_class
singapore
Re: variable Vth
Reply #7 - Aug 27th, 2005, 6:24am
Thanks everyone for the clue.
