m_h
Hello everybody, I am working on a gilbert cell mixer for direct conversion and I would like to simulate the DC Offset caused by LO self-mixing. I used QPSS analysis with 77 GHz(large) at LO port, and a 76.9 GHz(moderate) signal and a 77GHz(moderate) blocker at RF port. I also applied a transient simulation to cross check the results. I observed the following behaviour: In the transient simulation the IF output common mode voltage starts at e.g. 4.2 V and then ramps up to a steady state value of e.g. 4.8 V due to LO blocker at the RF port. Which seems reasonable. The QPSS analysis yields as DC voltage at the IF output of 4.2V. If I sweep the power level of the blocking signal the DC offset is still at 4.2V. How can I set up the QPSS analysis to make this kind of simulations? Thanks in advance for your help Marcus
