May 2nd, 2024, 9:32pm
How to Generate & view 1/f noise using spectre (Read 3680 times)
sphere83
Sep 17th, 2005, 12:07am
Hi guys,
I'm new to analog circuit design and I wish to know how to generate and view the 1/f noise spectrum of a simple nMOS transistor using Cadence spectre.
Please help & thanks in advance.
Kindest regards,
Sphere  :)
Re: How to Generate & view 1/f noise using spe
Reply #1 - Sep 19th, 2005, 8:42pm
I'm not entirely sure what you're asking here (it's a bit vague). In order to see 1/f noise, you need to have the appropriate parameters in your device models - exactly what those parameters are depends on the model type. Traditionally these were called af, ef, kf - but newer models have different parameters which can be used instead.
Apart from that it's a matter of doing a noise or sp analysis (or pnoise/psp, qpnoise/qpsp for periodic or quasi-periodic circuits) and looking at the results. Reading the manuals would probably help (Spectre user guide/reference guide and analog simulation help in cdsdoc).
Reply #2 - Sep 19th, 2005, 8:43pm
Also, since you posted this in the behavioural models section, perhaps you're asking how to do this in a behavioural model language? If so, you can use the flicker_noise() function in Verilog-A. But I suspect you just posted the question in the wrong place?
