jbdavid
the measurement you are talking about is something I call "Latency".. The way I would do this is to create model of the Sigma Delta ADC that has 0 latency, then add a number of registers on the output to hold the prior values up to (and including) the maximum possible latency of your SD-ADC.. Also provide a control bus on your model to allow selection of the various holding registers for your output.. - for a one time -visual- test compare the output of each of the registers to the output of the real ADC.. for a more automated test.. separate the registers from the Reference ADC model.. and write (as a verilog model) a model that will have the registers and comparsion blocks that will (on each clock edge) tell you which delayed output matches the SD-ADC under test. - to go further, consider finding the closest match to 2-4 samples, perhaps ignoring minor differences as small as 1-2 LSB's ------------ In an analog sense, you could turn the "under test" and "reference"(+ delayed) outputs back to analog levels and then take the difference between the test output and each delayed on.. Integrate these and the one closest to Zero after a representive sample set would give you the number of cycles of latency..
hope this helps, Jonathan
