Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
May 6
th
, 2024, 5:50pm
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› question on ldo voltage regulator
Previous topic
Next topic
question on ldo voltage regulator (Read 4039 times)
navin_kumar
Sep 21
st
, 2005, 4:47am
IN LINEAR CMOS LDO VOLTAGE REGULATORS
--STUDY SAYS THAT PMOS HAVE STABILITY PROBLEMS
COMPARED TO THE NMOS PASS ELEMENT
CLARIFY THE STABILITY POINT FOR ME
--WHETER BECAUSE NMOS WILL BE SOURCE FOLLOWER CONFIGURATION
SO IT IS HAVING LOW OUTPUT IIMPEDENCE
IP Logged
Re: question on ldo voltage regulator
Reply #1 -
Sep 21
st
, 2005, 9:07pm
Hello, Navin,
Yes. You are right.
Yawei
IP Logged
navin_kumar
Reply #2 -
Sep 21
st
, 2005, 11:07pm
Hi Yawei
thanks for clarifying the doubt
could u please give any good paper link for nmos pass element low drop out voltage regulator design
navin
IP Logged
ic_engr
Reply #3 -
Sep 22
nd
, 2005, 8:39am
Hello Navin,
There is a good paper in 2005 ISCAS Titled:
"A Low DropOut CMOS Regulator with High PSR Over Wdieband Frequencies" by V. Gupta
IP Logged
Reply #4 -
Sep 25
th
, 2005, 1:48am
Hi, Navin,
You can get Gupta's paper and many good references on the following link.
http://users.ece.gatech.edu/rincon-mora/publicat/pubs.htm
Best regards,
Yawei
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
