May 6th, 2024, 4:20pm
Pages: 1 2
Question on a VCO design with differential stage (Read 11678 times)
fehler
Re: Question on a VCO design with differential sta
Reply #15 - Oct 15th, 2005, 8:51pm
Dear Tumeda,
I am afraid that Barkhausen Criteria still holds for oscillator.
Although osciallator has no stable o.p, it is instructive to
check B.C. first. Please have a look at Razavi's paper.
My question is, how about your gain? I have a look on you
schematic, you have 4 stages, and one of them is cross- connected. And then it is sure that there will be a positive
feedback, if the gain condition is met.
Paul
Switzerland
Reply #16 - Oct 17th, 2005, 12:18am
as I already mentioned you should check the gain per stage. An oscillator (in the real world) starts up from noise, so you need enough gain...
Paul
Pages: 1 2
