chiu
Champaign-Urbana
Thanks for your suggestion.
I used a 1k resistor and a 1pF capacitor, sampled at 10MHz. The following is my PSS and PNOISE statement:
pss_x pss period=T tstab=0 maxacfreq=1000*fclk swp_x sweep param=nres values=[100 1k 10k] { pns_x (vo vss) pnoise start=0 stop=0.5*fclk lin=1e2 maxsideband=1000 \ noisetype=timedomain noisetimepoints=[0] numberofpoints=1 }
I got a total sampled noise 177, 56, and 18uV for the resistance 100, 1k, 10k ohm, respectively. Any suggestions?
