May 19th, 2024, 1:32am
Sampled noise simulation w/ Spectre (Read 2695 times)
chiu
Champaign-Urbana
Oct 11th, 2005, 7:55pm
The PNOISE analysis in Spectre gives strange results of sampled thermal noise from a simple resistor-capacitor network. After SINC compensation, the noise PSD is flat, but the integrated noise from 0 to fs/2 varies depending on the resistance R instead of 64uV/1pF fixed. Why is this?
- Yun Chiu
10/11/05
Frank Wiedmann
Munich, Germany
Re: Sampled noise simulation w/ Spectre
Reply #1 - Oct 11th, 2005, 11:33pm
Did you set the maxsideband parameter large enough? Please see section 2.2 of http://www.designers-guide.org/Analysis/sc-filters.pdf for details.
chiu
Champaign-Urbana
Reply #2 - Oct 12th, 2005, 3:51pm
Thanks for your suggestion.
I used a 1k resistor and a 1pF capacitor, sampled at 10MHz. The following is my PSS and PNOISE statement:
pss_x pss period=T tstab=0 maxacfreq=1000*fclk
swp_x sweep param=nres values=[100 1k 10k] {
   pns_x (vo vss) pnoise start=0 stop=0.5*fclk lin=1e2 maxsideband=1000 \
   noisetype=timedomain noisetimepoints=[0] numberofpoints=1
I got a total sampled noise 177, 56, and 18uV for the resistance 100, 1k, 10k ohm, respectively.
Any suggestions?
