Jul 24th, 2024, 10:32am
3f spur in current-steering DAC? (Read 2961 times)
rhys_williams
Sep 30th, 2005, 7:04am
I've been simulating a 12-bit current-steering DAC, initially with ideal current sources, switches etc. I've been introducing non-idealities into the current sources (6 binary-weighted sources, 6 thermometer-decoded bits) and looking at the effects on INL, DNL, SFDR, SNR etc. So far, so good.
Now I've moved on to using a couple of technology design kits and replaced the ideal components with transistor level schematics and their corresponding models. Simulations on my DAC now always show a strong peak at 3f that decreases the SFDR drastically. If I replace the current sources with ideal models the spur disappears. I've tried introducing various types of artificial mismatch into the ideal sources (up to 0.5 LSB) but all that does is raise the noise floor, not produce a sharp peak.
Any ideas where this 3f peak is coming from?
Re: 3f spur in current-steering DAC?
Reply #1 - Sep 30th, 2005, 9:35am
Rhys,
  Have you modeled the current sources as current
sources without output resistance and capacitance?
If you add the current source output resistance and
capacitance to the model do the results for the "ideal"
model match the transistor level results. In real DACs,
the output impedance is a function of the output code
level and this can cause distortion. In differential the
even-order terms cancel and the odd-order terms
become a problem.
rhys_williams
Reply #2 - Oct 3rd, 2005, 4:03am
Thanks Sheldon - I've just managed to replicate the 3f spur by using ideal sources in parallel with a resistance, to simulate the output impedance.
