May 17th, 2024, 2:46am
Q of the low pass filter (Read 5241 times)
Analoger
Oct 02nd, 2005, 10:41pm
I was a bit confused. I understand that quality factor "Q" is an important spec of bandpass filter. But what does quality factor mean for low pass filter? Why do we need to care about it? Thank you!
Analoger
Re: Q of the low pass filter
Reply #1 - Oct 4th, 2005, 8:23pm
Any comments, pls?
Anuranjan Jha
Guest
Reply #2 - Oct 10th, 2005, 11:19pm
For a low pass filter, Q does not make sense unless you specify the frequency. You may say Q is a function of frequency because the loss in the circuit depends on it.
Anuranjan
  IP Logged
Analoger
Reply #3 - Oct 15th, 2005, 9:26pm
Anuranjan , no offense, but i don't think you really understand the question and the definition of quality factor - which has different meanings under different circumstance.
Paul
Switzerland
Reply #4 - Oct 17th, 2005, 12:12am
I'm not sure who misunderstands the signification, in any case your question is ambiguous. I guess you are questioning the pole quality factor, not the filter quality factor. The pole quality factor defines who much damping your transient response shows, respectively how much peaking your frequency response exhibits. It essentially depends on the ration between the real and the imaginary parts of the poles. For a two-pole filter, you can find the math in any convenient text book. The following document discusses both quality factors:
http://www-inst.eecs.berkeley.edu/~ee247/fa04/lectures/L2_f04.pdf
Paul
Analoger
Reply #5 - Oct 17th, 2005, 10:31am
Hi Paul,
I understand the pole quality factor concept. The imaginary part of the pole determines the oscillation frequency, and the real part determines the damping.
I remembered I saw it somewere that "Q" of a low-pass filter is given as a spec. That's why I'm asking.
Thank  you.
Paul
Switzerland
Reply #6 - Oct 19th, 2005, 12:32am
But that certainly is the pole quality factor and not the filter quality factor.
Best
Paul
Juddy
Reply #7 - Oct 23rd, 2005, 6:55pm
By the way, I have also a question on Q of the LPF.
when we design a cascaded (two-stage) filter with each stage two poles, how to design the Q- of each stage, should the Q value of two-stages increase of decrease, thanks in advance!!!
