Aug 15th, 2024, 6:08am
Question for diva Rule modification (Read 150 times)
ethan
Oct 03rd, 2005, 7:18pm
Hi there,
I would like to try to modify diva Rule file to extract the subtrate for substrate coupling noise analysis. But I don't know where I can find related materials for explaining diva Rule.
Is there anybody know how to do this?
I know somebody has done this since I read it from their papers.
Many thanks.
Re: Question for diva Rule modification
Reply #1 - Oct 4th, 2005, 10:13pm
If you're looking for the Diva documentation, this is in <instdir>/doc/diva/diva.pdf and <instdir>/doc/divaref/divaref.pdf
Where <instdir> is your IC software installation path.
Reply #2 - Oct 4th, 2005, 10:14pm
Or of course you could run "cdsdoc" to invoke the Cadence documentation. Or hit the help menu in the CIW in DFII.
