May 19th, 2024, 1:14am
Return Loss Measurement & Balun (Read 7149 times)
giacomophx
Italy
Oct 07th, 2005, 11:31am
I built an ideal balun as in "Measuring S-Parameters of a Differential Mixer" and I am using it to measure the differential/common return loss of a 2 port device. I use spectre. The device is modeled as just 2 50Ohm resistors connected to ground in their center point (so 100 Ohm differential and 25 Ohm common mode). I have connected two ports to the balun:
port1 r=100 connected to terminal "d" of the balun
port2 r=25 connected to terminal "c" of the balun
resistors connected to terminal "p" and "n" respectively.
I chose sp analysis and I selected both ports.
The result is correct: S11=-300dB S22=-300dB so means perfect matching.
If I insted change the value of the two resistors to 80 and 20 respectively (so differential =100 and common mode = 16) the result are wrong: S11=S22=-20.1dB.
I was expecting S11=-300dB and S22=-13.1dB.
My conclusion is that I can use the balun to measure the S-Parameter only if the DUT is balanced in both the two inputs. Or, is not possible in one analysis calculate the differential/common return loss.
Any comments/suggestions are welcome,
Giacomo
Re: Return Loss Measurement & Balun
Reply #1 - Oct 7th, 2005, 11:33pm
The SPICE netlist version of the balun was updated back in February because of an error. You aren't, by chance, using an older version in SPICE netlist format?
sugar
Reply #2 - Oct 8th, 2005, 1:25am
hi Ken,
To simulate differential s-parameter between two nodes,
We only need to place a port cell between those two nodes, and then check s11.
Am I right?
From some meterial, I saw Cadence used a complex circuit which contains cccs and vcvs to simulate differential s-parameter. I believe there must be some reasons for Cadence to use that complex circuit. Could you give me some idea?
Reply #3 - Oct 8th, 2005, 8:56am
You can measure the differential S-parameters using a single port connected across the differential inputs, however this does not provide anything in the way of common-mode bias. If you also need to provide for the common-mode bias, you can use the testbench described in http://www.designers-guide.org/Analysis/diff-sp.pdf.
giacomophx
Italy
Reply #4 - Oct 8th, 2005, 11:59am
Hi Ken,
I am using this spectre netlist:
simulator lang=spectre
subckt balun (d c p n)
T1 (d 0 p c) transformer n1=2
T2 (d 0 c n) transformer n1=2
ends balun
I will send you the entire testbench netlist on monday.
Giacomo
