May 18th, 2024, 7:34am
Assura Extraction problem in IBM 7RF (Read 3259 times)
vipul
Oct 11th, 2005, 2:56am
I am using the IBM 7RF kit to design circuits for frequencies above 10GHz. The parasitic extraction using Assura seems to be inaccurate for parasitic resistances. Sometimes, it shows resistances as big as several kil-ohms, while Diva shows only a few ohms.
Has anyone had a similar problem? Is it a bug?
I am using IC5141 and Assura 314 on a Linux machine.
Is Diva reliable? (e.g how much deviation can I expect in measurements)
I can provide more details of what procedure I am following exacly, if that helps.
Vipul
Re: Assura Extraction problem in IBM 7RF
Reply #1 - Oct 12th, 2005, 1:45pm
Note that Assura tends to lump together resistors far more than Diva does - Diva often leaves lots of small resistors in a complex mesh, because it does only limited reduction (and even then, it will only reduce if it can make the network smaller with the same overall resistance, and it will only combine resistors which came from the same layer - if my memory is correct).
So you may not be comparing like with like?
Any concerns you have over accuracy of the extraction rules should go to IBM, I'd have thought.
vipul
Reply #2 - Oct 14th, 2005, 12:57am
I found the answer on the Cadence Sourcelink website. Assura does some Wye to Dlta transformations on the resistive network that it extracts, and in turn comes up with large values. This does not affect the electrical equivalence of the extracted view; just that what it back-annotates on the schematic gives the user a wrong impression. A work-around is to specify a larger value for the minR parameter.
I have some more problems that I am writing in a separate post.
Thanks for your help
Vipul
