May 18th, 2024, 12:14pm
AHB Slave.. (Read 2801 times)
hardik
AHB Slave..
Oct 14th, 2005, 1:42am
hi,
i m designing an AHB slave..can u tell me how can i use HINDEX to select the correct SLAVE select signal for me??
thank u,
hardik
jbdavid
Re: AHB Slave..
Reply #1 - Oct 17th, 2005, 1:06am
Not knowing what AHB you are referring to.. a quick websearch found a couple of references to Eureka Technologies, and the Advanced High-performance Bus..
and I think you are asking a question about the Bus interface itself, rather than about modeling its behavior.
- Please understand that HERE, AHDL is for ANALOG HDL, which describes a blocks ELECTRICAL characteristics, and very few of use are even aware that ALTERA has a proprietary Digital HDL they also call AHDL (I think its kept around for backward compatibility ??)
Just to be clear.. I am NOT aware of any HINDEX feature in Verilog-A, Verilog, or Verilog-AMS, so I am at a loss for giving you further help..
jbd
jbdavid
