May 10th, 2024, 12:40am
Help on layout for power transistor (Read 5903 times)
Oct 20th, 2005, 10:43pm
I am designing a LDO with about 20mA output current.
Would you please introduce any books or tutorials on the layout for power transistor?
Yawei
Re: Help on layout for power transistor
Reply #1 - Oct 21st, 2005, 8:29am
Yawei,
  Hastings book, listed in the books of the Designers guide,
section, includes discussion of power transistor layout. The
second edition is now available.
Reply #2 - Aug 3rd, 2006, 4:28pm
MOS or Bipolar?
The MOS devices are straightforward, just be very fussy about minimizing all your metal and contac resistance paths.
A bipolar one is a lot more picky, bipolar power transistors require ballast in the form of emitter resistance to make sure the currents all balance across the Vbe junctons of the parallel devices. Otherwise one junction runs hot, and all the current goes through there until that junction fries. (Warning - Not seen in simulation!)
On the LDO, be careful with the feedback stability, and the ESR of the compensation network.
Jerry
richard88
Reply #3 - Aug 24th, 2006, 10:15pm
Sheldon,
 I've the first edition. Could you provide the important difference between the two editions ?
 I also like the first edition.
Richard
sheldon wrote on Oct 21st, 2005, 8:29am:
Yawei,
