May 21st, 2024, 12:13am
Impedance probe in SpectreRF (Read 2751 times)
Dan
Pittsburgh PA
Nov 16th, 2005, 2:30pm
Hello
I am working on a multi-stage PA in SpectreRF and have run across difficulties in designing the interstage match networks.  Would anyone know of a method of measuring impedance without breaking the circuit?  I can use the RF ports in the s-parameter simulation to measure input and output impedance of the amplifier.  But I can see no option to measure the Z load of the interstage match network, for example.  This can be estimated by breaking the circuit and wiring an RF port to this point, but the parasitics will change.  Is there a method for designing a non-invasive reflection coefficient probe, and having this measurement roll into the s-parameter menu?
Thank you for your time,
Dan
Jess Chen
California Bay Area
Re: Impedance probe in SpectreRF
Reply #1 - Nov 16th, 2005, 2:45pm
As I understand your problem, you want to measure the impedance looking into a load while it is being driving by another circuit. If that is true, you should be able to drive the node between the source and load with a current source and place current probes on either side of the injection point. You can then compute zload, as well as zsource, by taking the ratio of the voltage at that node to the appropriate current.  You can then convert the impedances to reflection coefficients. You should be able to write some waveform calculator functions to streamline the computations.
Dan
Pittsburgh PA
Reply #2 - Nov 18th, 2005, 7:15am
Thank you for your input Jess.   I'll give this a try for a few frequency points.
Dan
