With the spectre interface there is no "SPSS" analysis (primarily because there is no SPSS analysis natively in spectre). On the choose analysis form for pss, there is a checkbox near the bottom labelled "sweep" which is how you set up a sweep.
That said, you can also do a sweep using Tools->Parametric Analysis - but it's more direct using the sweep on the pss form.
Also, in order to plot IIP3, you don't actually have to do a sweep - since IIP3 is measured at a single input power. That said, people like to sweep input power as it enables you to check that you're measuring it in the right place (and have picked the correct harmonics).
