May 21st, 2024, 12:23am
Mixer IIP3 (Read 5268 times)
joggu
Guest
Mixer IIP3
Nov 23rd, 2005, 11:35pm
I am having some problem getting Pdisto or spss analysis to run in SPECTRES..howevr SPECTRE runs fine and I can do PSS , PAC etc
So if someoen cud tell me how I coud simulate IIP3 and IIP2 of LNA, mixer, baseband amplifier combined without using spss, it will be grt.
The probelm with SPECTRES is that when I give the model path name it gives a warning and no simulation runs..lots of us are having this problem..but in SPECTRE we browse and add the file and it works fine.
Thanks, Debo
  IP Logged
Re: Mixer IIP3
Reply #1 - Nov 27th, 2005, 5:03am
If you can run OK with the newer spectre interface, then use that. The spectreS interface is obsolete and should only be used if you have no other choice - it doesn't support many of the newer analyses as it has not been updated for several releases, and will be going away shortly.
Since you say you can run with the spectre interface, you should be able to run any swept analyses too.
You don't really give any details of what the problems are with your simulation run, so I can't give any more specific help, I'm afraid.
joy
Guest
Re: Mixer IIP3
Reply #2 - Nov 28th, 2005, 12:19am
The spectre that we have doesnt have any SPSS analysis option. It has pss, qpss, pac, pnoise but no spss or pdisto..so i cant get IIP3 curves. Any help will be grt!
Rgds, Joy
  IP Logged
Re: Mixer IIP3
Reply #3 - Nov 28th, 2005, 5:01am
With the spectre interface there is no "SPSS" analysis (primarily because there is no SPSS analysis natively in spectre). On the choose analysis form for pss, there is a checkbox near the bottom labelled "sweep" which is how you set up a sweep.
That said, you can also do a sweep using Tools->Parametric Analysis - but it's more direct using the sweep on the pss form.
Also, in order to plot IIP3, you don't actually have to do a sweep - since IIP3 is measured at a single input power. That said, people like to sweep input power as it enables you to check that you're measuring it in the right place (and have picked the correct harmonics).
joy
Guest
Re: Mixer IIP3
Reply #4 - Nov 29th, 2005, 12:46am
Hi Andrew,
 Thanks a lot for ur help! I looked up and saw that there is a sweep option, and I can sweep input voltage. But how can i get values of iip2 and iip3 directly from this simulation? if you wud explain in a bit more detail, I will be highly obliged. I need to get IIP2 and IIP3 values for my circuit very soon
thanks once again,
rgds, joy
  IP Logged
Re: Mixer IIP3
Reply #5 - Nov 29th, 2005, 8:44am
Please read the SpectreRF User Guide. It's covered there.
Either look for this in cdsdoc, or:
<instdir>/doc/spectreRF/spectreRF.pdf
