Aug 15th, 2024, 5:22am
N-Well Shielding (Read 3408 times)
uncle_ezra
N-Well Shielding
Nov 24th, 2005, 3:40am
In a p-type substrate, the n-well can be placed under capacitors, inductors and resistors to provide a low-capacitance shield. My question is whether you can leave the n-well terminal floating? In simulation it seems to be ok but not sure if there will be any side effects after fabrication.
I know ideally you want to connect to a clean Vdd but since I don't have that available is it ok to leave the terminal floating?
uncle_ezra
Re: N-Well Shielding
Reply #1 - Nov 28th, 2005, 1:18am
So I was told it is ok to leave the terminal floating.
hrkhari
Reply #2 - Dec 18th, 2005, 5:50pm
I believe that the n-well shielding should be connected to Vdd to further avoid accumulation of stray charges if it is left floating.
Rgds
Paul
Switzerland
Reply #3 - Dec 19th, 2005, 1:13pm
I have seen both and if your foundry does not explicitly forbid this practice (DRC rules), it should be OK to leave it floating. Don't forget however that the result is not the same. In one case your inductor/resistor sees a fixed parasitic capacitor to a clean Vdd, in the other case (floating) it sees a capacitive divider to the possibly noisy substrate. The latter is usually better for speed, but not always for parasitic coupling.
Paul
