Paul
I have seen both and if your foundry does not explicitly forbid this practice (DRC rules), it should be OK to leave it floating. Don't forget however that the result is not the same. In one case your inductor/resistor sees a fixed parasitic capacitor to a clean Vdd, in the other case (floating) it sees a capacitive divider to the possibly noisy substrate. The latter is usually better for speed, but not always for parasitic coupling.
Paul
