You could try to use an assignment to an OOMR. In other words, you could have a real variable inside your DUT that contains the input value, and you can assign to it directly from within your testbench using a hierarchical reference. There are some restrictions in the language you might have to try to work around. For example, this will not work if the real variable is owned by the analog context. It also will not work if the input changes continuously.
