May 18th, 2024, 8:39am
WARBURG impedance (Read 68 times)
OpAmp
WARBURG impedance
Jan 05th, 2006, 9:44pm
I’m trying to model a WARBURG impedance (Usually discussed in electrochemistry)  in HSPICE. Your helps are greatly appreciated.
OpAmp
Re: WARBURG impedance
Reply #1 - Jan 6th, 2006, 5:12am
Perhaps you could post some links to describing the effect, or better yet, distill them to a few equations?
HSpice's dependent sources allow fairly arbitrary expressions, you just have to reduce the physics to "through" and "across" variables (through=current, across=voltage). Verilog-A (the modeling language) has a natural way of setting up these equivalences, but if you can keep things straight in your head, you should be able to work with standard HSpice.
