May 18th, 2024, 12:46pm
Silicon Area calculation from Schematic (Read 5424 times)
silicon_holmes
Let there be light
Bangalore
Feb 17th, 2006, 1:56am
hi, i'm relatively new to the analog layout field. I'm facing a problem now. i have a set of schematics with me to do the layout. before that is done, the PD team need the abstract views of those blocks to do P&R.
Is there any way to do this? i use a cadence DF2 platform. when i use the Floor plan/ Schematic option in the composer, i need an area calculation SKILL function in place. i dont have anything like that now.
will anybody help me on this topic.
Thanks and regards,
Re: Silicon Area calculation from Schematic
Reply #1 - Feb 18th, 2006, 6:33am
Yes, read the manual. I'm pretty certain this is covered in the Preview documentation.
silicon_holmes
Let there be light
Bangalore
Reply #2 - Feb 19th, 2006, 8:13pm
Hi Andrew,
thanks for your reply. but i'm still at loss. is it possible for you to be more specific about those documents. i had a talk with a cadence person. according to him it is not possible to create LEF views from schematic.
my doubt is that, can i produce some sort of estimation from the schematic that can be used by the P&R tool? what is the general method used in the industry in these kind of situations?
i have access to Virtuoso XL layout editor. it is giving some area estimate when i use gen from source option. i'm not sure about the accuracy of that estimate.
thanks in advance
Reply #3 - Feb 20th, 2006, 9:11am
This is not really my main area of expertise, but I just had a quick look in the Preview Reference documentation:
<instdir>/doc/prfref/prfref.pdf
If you look in Appendix F there is a section on "Sample Area Estimator Functions", and it references Chapter 4
which explains how these are used. It's possible to start all this from a schematic based design.
Note that Preview is included as part of VirtuosoXL these days. I'm sure that's what it is you're trying to use...
silicon_holmes
Let there be light
Bangalore
Reply #4 - Feb 21st, 2006, 5:01am
that was really helpful. thank you very much. i'm currently doing the assessment using the XL tool. it is giving some good estimates when i use Gen from Schematic option. i feel the prboundary area calculation used in that form is much better than other skill functions. it is doing well with designs with less hierarchy. so i'm finding an estimate of lower level blocks with XL and then use those to assess the top.
hopefully, it should give some good results.
Thanks and regards
Grin
