May 5th, 2024, 12:31am
Pages: 1 2
Frequency-to-current converter in phase domain (Read 12951 times)
Emre
Re: Frequency-to-current converter in phase domain
Reply #15 - Mar 06th, 2006, 8:38am
Thanks for the advices.
With new initial step definitions, I have almost full control on the model. I also added an initial condition to frequency node and it works nice.
About the dc path to ground issue, I'm using a large resistor, but so large resistor results in exceeding the blowup limit for the voltage. 100Mohm works ok. But I still would like to learn, how I can make the transient analysis by skipping the dc solution, as Ken offered. Can you please tell me, how it can be done.
Emre
Reply #16 - Mar 6th, 2006, 10:51am
There is a transient analysis option, either skipdc or dcskip. Try 'spectre -h tran'.
Pages: 1 2
