Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
May 18
th
, 2024, 4:31am
Home
Help
Search
Login
Register
PM to admin
Other CAD Tools
Entry Tools
› Problems to start LVS in assura3.1.4
Previous topic
Next topic
Problems to start LVS in assura3.1.4 (Read 3390 times)
cyrus
Mar 01
st
, 2006, 5:36am
Hello together,
I have the following problem during the LVS check. When I start the LVS I get the following
the message that the LVS failed. The problem is described as follows: Segementation violation
Did someone has this problem ? Is this a bug? Because with assura 3.1.2 the LVS runs.
Greetz
IP Logged
Paul
Switzerland
Re: Problems to start LVS in assura3.1.4
Reply #1 -
Mar 1
st
, 2006, 12:50pm
Cyrus,
you mentioned Assura 3.1.2, but what version are you currently using? What Cadence version are you using, what is your OS (type and release)?
Did you check Sourcelink for possible solved problems?
Paul
IP Logged
cyrus
Reply #2 -
Mar 2
nd
, 2006, 8:58am
As mentioned in the top line I used assura 3.1.4 that did not run!
The software is installed on a solaris workstation SunOS 5.8. Cadence version is 5.1.41
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
»» Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
