jbdavid
In the case of a VOLTAGE output which I want to have as a resistor, I usually, V(iOut) <+ vout; I(Out,iOut) <+ V(Out,iOut)*Rout..
- of course its even better to use a transition on Rout, and since its probably to transition the EXPONENT of R not R itself. Ron Vogelsong has written a number of modules like that .. if you have access to Cadence SW, look in bmslib for sw_no for a great example. Jbd
