May 18th, 2024, 10:00am
Modeling high-z output in verilog-A (Read 1580 times)
steve_mac
Mar 18th, 2006, 6:19am
How do i model high-z output in verilog-A ?
Currently I'm modeling it to output = 0, but it is causing conflict when i cascode them at top level (error = output connected to another output).
Currently the method i'm using is
vout = 0;
V(OUT) <+ vout ;
With what value should i replace the '0' with in order to get a high-z output?
Thanks a million for ur help !!!!!
Marq Kole
Eindhoven, The Netherlands
Re: Modeling high-z output in verilog-A
Reply #1 - Mar 20th, 2006, 12:51am
Hi Steve,
A different approach might be to use indirect branch assignment (see LRM 2.2 section 5.3.2). In your case the statement:
V(OUT) <+ 0;
should be translated to:
V(IN): V(OUT) == 0;
Assuming there is a V(IN) and that it is (through the external circuit) connected to V(OUT) such that the simulator can solve for V(OUT) == 0.
If there is no such connection or no additional input (or inout) is available, you'll probably have to resort to either a very high output resistane (1TOhm) or connection through a controlled current source.
Eugene
Reply #2 - Mar 20th, 2006, 7:50am
For a high impedance output, are you sure you don't want to instead use
I(out) <+ 0;
Marq Kole
Reply #3 - Mar 20th, 2006, 8:09am
To prevent the "error = output connected to another output" it should also suffice to change the mode of the port OUT from "output" to "inout".
jbdavid
Reply #4 - Apr 1st, 2006, 10:03pm
In the case of a VOLTAGE output which I want to have as a resistor,
I usually,
V(iOut) <+ vout;
I(Out,iOut) <+ V(Out,iOut)*Rout..
- of course its even better to use a transition on Rout, and since its probably
to transition the EXPONENT of R not R itself.
Ron Vogelsong has written a number of modules like that ..
if you have access to Cadence SW, look in bmslib for sw_no
for a great example.
Jbd
jbdavid
Reply #5 - Apr 2nd, 2006, 12:09am
It would be more efficient to avoid the use of the internal node iOut and just use
V(out) <+ vout + Rout*I(out);
jbdavid
Reply #6 - Apr 21st, 2006, 2:06am
maybe.. But I like to make the full branch explicit when I declare currents..
Jonathan
jbdavid
