Edited: 3. Now to simulate, I open Analog Environment from Tools>Analog Environment.
The Analog Environment offers a variety of simulators, is it not
enough to create a VerilogAMS view to simulate with AMS.
Check under Setup->Simulator/Host, which Simulator is set.
Have you chosen AMS there?
Edited: 4. There if I click the 'Green light' to run simulation, I get those errors. I've tried to change the switch and stop list. But it did not work
It is also not enough to change the switch and stop list in the
environment settings of the Analog Environment you have to create
a so called configuration view in the Hierarchy Editor and partitioning
your design there.
Form my point of view it is not that straight forward to setup AMS Designer if your Design-Kit does not support this and your not familiar doing tool setup kind of things.
There will be sure a lot of more sticking points and I'm not quite
sure at which level you currently are?
Bernd
