Jun 30th, 2025, 3:30pm
Verilog A Event (Read 3993 times)
yaxazaa
Verilog A Event
Mar 22nd, 2006, 4:44pm
Can someone tell me how to do integration between two events in Verilog-A? Foe example, when signal a passed trigger point, the function starts to do integration, after detected signal b passed trigger point, intergation stop.
Thanks.
Re: Verilog A Event
Reply #1 - Mar 23rd, 2006, 5:49am
@(initial_step) integ = 0;
@(cross(V(ctrl), +1)) integ = 1; // triggers when V(ctrl) crosses 0 in the positive direction
@(cross(V(ctrl)-2,+1)) integ = 0; // triggers when V(ctrl) crosses 2 in the positive direction
V(out) <+ idt(integ * V(in), 0);
Note that V(ctrl) must start below zero, or else the cross function won't detect a crossing.
Marq Kole
Eindhoven, The Netherlands
Re: Verilog A Event
Reply #2 - Mar 24th, 2006, 2:18am
Or use the @(above) event if you want V(ctrl) to be able to start above 0 from the start of your simulation. With @(above) the event is triggered also during (implicit) DC analysis.
@(above(V(ctrl))) integ = 1;
@(above(V(ctrl))) integ = 0;
BTW @(above) is an Verilog-AMS 2.2 feature so may not be available in all simulators yet.
Alternatively, test for V(ctrl) during the @(initial_step)
@(initial_step) integ = (V(ctrl) > 0) ? ((V(ctrl) > 2) ? 0 : 1) : 0;
