May 21st, 2024, 11:02am
puzzle about 5V tolerance of 3.3V CMOS (Read 4123 times)
boris
OK
Mar 29th, 2006, 4:51am
the following circuit is used as 5V tolerance input circuit for a 3.3V CMOS process.
all the MOSs are 3.3V devices.
as I know, the break-down voltage of the PN junction between the drain and the substrate of N3 is not higher than the break-down voltage of the gate of N2. So I think that using N3 to tolerance 5V is not reasonable.
who can tell me why I am wrong.
BTW, when the PAD is 5V, the ESD device of P1 is turned on so it is not good here. Am I right? What is the better solution for ESD?
Alef
Re: puzzle about 5V tolerance of 3.3V CMOS
Reply #1 - Apr 12th, 2006, 11:50pm
You can use TTL to CMOS schmitt trigger in this case. Transistor P1 will wark as diode while scheme is normal working. The most simple decision is usage of the diode chain instead of P1 or excluding P1 from the curcuit. In this case ESD stress current will flow through the alternative pathes: through N1 to ground rail then to power rail through ground to power diode chain or clamp curcuit.
mikki33
Analog/Mixed
Signal/High Speed
Israel
Reply #2 - May 17th, 2006, 1:58am
[quote author=boris]
[quote]
You are wrong in this statement. The N+/P-sub break-down in higher than 5V for sure. If I recall correccly it is 10-12V. You can check it by simulating N+/P-sub reverse-biased diode and see. (if of course you have reliable and good models from the FAB).
You are also wrong in the statement about the P1 is turning on. It is not. First, the Vt of 3.3V transistors is about 0.7V, but the voltage at the pad NEIVER reach 5V, because: second, P+/NWELL diode (which is the drain of P1) becomes forward biased and opens when the pad voltage reaches Vt of this diode (it may be 0.4-0.6V) above VDD (the voltage of the NWELL). You also can simulate P+/NWELL diode (in this case forward biased) and see when it will open (i.e. find the diode Vt).
Best,
Michael
« Last Edit: May 17th, 2006, 8:21am by mikki33 »
If you don't have time to do it good
you will find time to do it again
