David Sobel
Univ of California--Berkeley
Maybe I'm being a little simplistic, but doesn't "No space on device" mean that your harddisk is full? Have you double-checked that you have space available on the harddisk? Be sure to check all the possible destinations that your PEX might be writing to. Best way to do that is to type "df ." from each directory where the PEX routine writes files.
Best, David
