May 18th, 2024, 12:15pm
Parasitic Extraction using Calibre (Read 4205 times)
ssk_288
Miles to Go
Bangalore
Apr 06th, 2006, 10:53am
Hi ,
I am trying to extract parasitic Capacitance and resistance from a layout using Calibre PEX. But it exits with a message
LVS_SPICE_ABORT: No space left on device
Fatal Error accessing file "/srv/tools/Mentor/Calibre/ixl_cal_2005.4_14.18/tmp/lvs.temp.3.1144394030.13277.
0"
*** Calibre finished with Exit Code: 1 ***
Can anyone please help
SUDHIR
David Sobel
Univ of California--Berkeley
Re: Parasitic Extraction using Calibre
Reply #1 - Apr 12th, 2006, 11:07am
Maybe I'm being a little simplistic, but doesn't "No space on device" mean that your harddisk is full? Have you double-checked that you have space available on the harddisk? Be sure to check all the possible destinations that your PEX might be writing to. Best way to do that is to type "df ." from each directory where the PEX routine writes files.
Best,
David
View Profile dasobel   IP Logged
