There are connect rules provided by cadence, instructions on setting those up should have been in the tutorial..
if you have a sourcelink account you can read the latest version of the tutorial - or find solutions that pertain to this.. (5.5 has been around quite awhile. )
But you do need a connectLib in your cds.lib,
and while you can point to the one in the IUS Install,
I prefer to copy it to my own library and customize it..
So you might not have noticed the part of the setup where the connecLib was added to the cds.lib file?
- AH YES - there is a POST LOAD Install script that has to be run by the person who installed the tools..
Code:cds_root ncvlog
cds_root ncvlog | pushd -
tools/affirma_ams/etc/install/amsConnectLibCompile
popd
THEN add the following line to your cds.lib
Code:SOFTDEFINE connectLib $(inst_root_with:tools/bin/ncsim)/tools/affirma_ams/etc/connect_lib/connectLib
OR
Code:SOFTINCLUDE $(inst_root_with:tools/bin/ncsim)/tools/affirma_ams/etc/connect_lib/cds.lib
- but you have to have the cadmgr run that script for the rest of that stuff to be there..
