Aug 17th, 2024, 3:23pm
low voltage buffer (Read 1807 times)
grosser
low voltage buffer
May 04th, 2006, 8:53am
hello everyone
i'm here the first time
could you recommend a buffer which will work fine with vdd=1.3V and threshold 0.6V or -0.75V.
simple source follower doesn't fit. i want it in LDO design, to move the second pole to higher frequencies.
nmos type source follower can fully turn on power device, but can't turn it off. the situation is inversely with pmos type source follower.
the buffer should be able to give large amounts of current to drive latge power device's capacity
regards
Raul
San Jose, CA.
Re: low voltage buffer
Reply #1 - May 4th, 2006, 11:31am
Like you said in your email; NMOS doesn't work because you can't turn-off the device under no load and standard Vt PMOS will not work at such low Vdd. You need to use a low-Vt PMOS follower or a Natural Vt NMOS follower based structure. Maybe you can lower the Vt of the PMOS power driver or PMOS buffer to save headroom at high load or lower the Vt of the NMOS follower if you don't have the two components previously mentioned.
I've got two patents on how to play this game, of course you can't use them unless you work at TI or a company that has cross-licensing with them, but you may get some inspiration:
1. US Patent 6,861,832
2. US Patent 6,646,495
Good luck.
regards, Raul Perez
