Jul 18th, 2024, 1:30am
How to model this subcircuit in Virtuoso (Read 3963 times)
jimmy
May 04th, 2006, 10:22pm
I want to make the schematic for the following subcircuit in cadence with Virtuosos. I don't know which component I should use to describe the controlled voltage/current sources whose values are functions of terminal's voltage/current and the other controlled source's value. Please help.
.subckt com 1 2 3 4 5
E1 1 2 value=((1-v(5))*v(3,4)/v(5))
G1 4 3 value=((1-v(5))*I(E1)/v(5))
.ends
thank you very much,
jimmy
bernd
Munich/Germany
Re: How to model this subcircuit in Virtuoso
Reply #1 - May 5th, 2006, 1:21am
Have you tried the depended sources form 'analogLib'
vcvs (voltage controlled voltage source) and
vccs (voltage controlled current source).
But I'm pretty uncertain that you can use the value as a
function of the terminal with them.
For more info see the Docs, 'Analog Library Reference Guide',
chapter 6, 'Sources - Dependent Components'.
Or maybe VerilogA modelling is an option for you there are
example sources in the sample library 'ahdlLib',
(/<instDir>/tools/dfII/samples/artist/ahdlLib)
Cells: vccs_hdl and vcvs_hdl
Bernd
Just another lonesome cad guy
aamar
Reply #2 - May 5th, 2006, 1:44am
Hallo,
If you can use spectre then do the following
The voltage/current controlled source is called bsource in spectre language
so you can define it as follows
simulator lang = spectre
subckt com 1 2 3 4 5'
i1 (4 3) bsource i=((1-v(5,0))*i("E1")/v(5,0))
ends com
inorder to create a symbol for this subcircuit  follow the following link:
http://www.designers-guide.org/Forum/YaBB.pl?num=1118940189/0#0
Best regards,
aamar
