Jul 18th, 2024, 3:35am
TR in the Hspice for BJT (Read 2481 times)
XORGate
May 23rd, 2006, 5:26am
What is the TR in the Hspice for BJT ? How to estimate?
Thanks!
Re: TR in the Hspice for BJT
Reply #1 - May 29th, 2006, 5:13am
This question may mean something to you, but I doubt it means much to anyone else! Can you expand such that somebody might stand some chance of figuring out what it is you're asking? Otherwise you're unlikely to get an answer.
mikki33
Analog/Mixed
Signal/High Speed
Israel
Reply #2 - May 29th, 2006, 7:38am
TR stands for base charge storage reverse transit time. Level 1and Level 2 have default value is zero. Level 4 has default value 1e-11 seconds.
For Level 8 model TR is time constant for inverse operation (default equals 1e-9 seconds).
For Level 9 TR is reverse transit time (default is 0).
For Level 11 TR is reverse charge storage time, intrinsic BC diode (default is 0).
If you don't have time to do it good
you will find time to do it again
