Jul 19th, 2024, 1:16am
NF / M BSIM parameter (Read 8167 times)
mkaragou
Germany Soest
Jun 09th, 2006, 4:56am
What is the difference between the parameters M and NF of the BSIM model?
My spectre documentation states:
M=Multiplicity factor(number of MOSFETs in parallel)
NF=number of device fingers
When I have two device fingers I have two MOSFETS in parallel, or not?
So what is the difference?
Is it the number of drain and source contacts?
bernd
Munich/Germany
Re: NF / M BSIM parameter
Reply #1 - Jun 9th, 2006, 8:25am
m is a bsim instance parameter which is defined as
'Multiplicity factor (number of MOSFETs in parallel)'.
nf is not a bsim parameter it might be a parameter of
a transistor subcircuit in your environment, (for number of fingers) .
If both are available for one MOS it's confusing,
maybe nf is used to calculate drain and source perimeter
and area for multifinger devices.
Bernd
Just another lonesome cad guy
mkaragou
Germany Soest
Reply #2 - Jun 9th, 2006, 11:55am
NF is a BSIM4 parameter!!!!
At least it is listed in the "spectre user guide" documentation!
mikki33
Analog/Mixed
Signal/High Speed
Israel
Reply #3 - Jun 11th, 2006, 8:55am
NF and M are interchangable paraneters. You may use or one or another.
It is generally used for circuit driven layout and depends on the company methodology.
NF: you are defining Total Width and NF, and stating where you want the lowest (drain or source) capacitance.
In this case width per finger is calculated.
M: you are defining Width and M, Total Width is calculated.
If you don't have time to do it good
you will find time to do it again
bernd
Munich/Germany
Reply #4 - Jun 12th, 2006, 3:26am
You're right I'm still thinking bsim3v3 Wink.
I think m is for parallel MOSs, whereas nf relay intents to be
more layout specific for parallel MOSs with shared diffusion (S/D) areas,
This is not required for m.
Have a look at my attacment
A.11 Layout-Dependent Parasitics Model Parameters
So I strongly believe its layout style depended.
Reply #5 - Jun 12th, 2006, 4:15am
mikki33 wrote on Jun 11th, 2006, 8:55am:
Yikes!  That is a dangerously untrue statement, and it's a little hard to decipher the truth from what you wrote later.
"m" is generally defined as the "number of (identical) parallel devices" -- and implemented in the simulator, rather than in the model source code that one might get from Berkeley.
"nf" is, as Bernd wrote, a way of specifying some geometry information pre-layout.
But it's important to know that
 m1 d g 0 0 nch w=1u l=0.18u m=100
is definitely not the same as
 m1 d g 0 0 nch w=1u l=0.18u nf=100
The first will have 100 devices, each with a drawn width of 1u.  The second will have 100 poly gates each with a width of 0.01u.
mikki33
Analog/Mixed
Signal/High Speed
Israel
Reply #6 - Jun 12th, 2006, 8:24am
It was actually, what I intended to say. I didn't write they are the same, because they are not.
Sorry for the confusion.
mkaragou
Germany Soest
Reply #7 - Jun 12th, 2006, 8:28am
Quote:
nf relay intents to be more layout specific for parallel MOSs with shared diffusion (S/D) areas
This makes sense to me, because the number of shared diffusion would for example affect the
amount of drain/source junction capacitance or the drain/source resistance that without the parameter nf
would not be taken into consideration by simulation.
But this means that I have to make layout decisions already during my early simulation phase.
