May 19th, 2024, 9:17am
Basic Verilog-A question (Read 3065 times)
carbonnanotube
Jun 11th, 2006, 6:10am
Hi everybody,
I'm rather new to the topic of Verilog-A modelling; thus, I'm playing ariound with some simple models in order to get a feeling for the concepts. Doing so, I encountered a (in my opinion) strange "effect": I modelled a simple circuit (R parallel C) and simulated with Cadence Spectre:
module simpleRC(A, B);
electrical A, B;
branch (A, B) Cap;
branch (A, B) Res;
parameter real R = 1e3;
parameter real C = 1e-6;
analog begin
 I(Cap) <+ ddt(V(Cap))*C;
 V(Res) <+ I(Res)*R;
which works fine. Then I change the model to the following:
electrical A, B;
branch (A, B) RC;
analog begin
 V(RC) <+ I(RC)*R;
 I(RC) <+ ddt(V(RC))*C;
which still works (!!). That is confusing for me as I expected that the RC-Branch switches to be a flow branch representing a C only (without the parallel R).
Could anybody kindly clear this up?
Oliver
Re: Basic Verilog-A question
Reply #1 - Jun 11th, 2006, 8:27am
It seems wrong to me too. I suggest you talk to Cadence about it. Please post their response.
Reply #2 - Jun 12th, 2006, 4:01am
Indeed, the branch value retention rules (see Section 5.3.1.3 in the Verilog-AMS LRM version 2.2) indicate that the module should act as just a capacitor; the potential contribution should be discarded.
carbonnanotube
Reply #3 - Jun 12th, 2006, 6:05am
Thanks for the information.
Unfortunately, we don't have Cadence support (we are a university using Europractice). Thus, I see no way to discuss that problem with Cadence directly.
-Oliver
