vivkr
I am new to Verilog-A and especially to the mixed-signal aspect of it. I just tried to copy out a simple 1-bit DAC example as shown in the Cadence user manual for Verilog-AMS, and I get errors in compilation. The messages all read like:
Error: left operand of type node not supported for operator '*' Error: right operand of type *undef* not supported for operator '+'
and so on...
The code which I directly copied down, cutting out a few nodes is shown below. I don't quite understand why an example provided by Cadence would not compile. Perhaps, this is a very trivial question, but I would be glad to have suggestions. I am trying to build a Verilog-AMS interface for my analog block to a Verilog code, and SpectreHDL, which I normally use for analog modelling is not supported for mixed-signal simulations with AMS-Designer.
Thanks Vivek
`include "constants.vams" `include "disciplines.vams"
module DACMacroExample(b0, b1, b2, b3, compSig); input b0, b1, b2, b3; output compSig;
logic b0, b1, b2, b3; electrical compSig;
parameter real refVolt = 2.5;
analog begin V(compSig) <+ (refVolt/16)*(b0 + 2*(b1 + 2*(b2 + 2*b3))); end endmodule
