May 19th, 2024, 8:26am
defining mixed-signal blocks (Read 2574 times)
vivkr
Jul 06th, 2006, 7:43am
I am new to Verilog-A and especially to the mixed-signal aspect of it. I just tried to copy out a simple 1-bit DAC example as shown in the Cadence user manual for Verilog-AMS, and I get errors in compilation. The messages all read like:
Error: left operand of type node not supported for operator '*'
Error: right operand of type *undef* not supported for operator '+'
and so on...
The code which I directly copied down, cutting out a few nodes is shown below.
I don't quite understand why an example provided by Cadence would not compile.
Perhaps, this is a very trivial question, but I would be glad to have suggestions. I am
trying to build a Verilog-AMS interface for my analog block to a Verilog code, and SpectreHDL, which I normally use for analog modelling is not supported for mixed-signal simulations with AMS-Designer.
Vivek
`include "constants.vams"
`include "disciplines.vams"
module DACMacroExample(b0, b1, b2, b3, compSig);
input b0, b1, b2, b3;
output compSig;
logic b0, b1, b2, b3;
electrical compSig;
parameter real refVolt = 2.5;
analog
     begin
           V(compSig) <+ (refVolt/16)*(b0 + 2*(b1 + 2*(b2 + 2*b3)));
vivkr
Re: defining mixed-signal blocks
Reply #1 - Jul 6th, 2006, 8:03am
I was able to find the source of the errors. I had been creating the cellviews as "veriloga" instead of "verilogams" and hence there was some syntax incompatibility (I think). Now, I have a block. Let me see how I can use AMS-Designer now.
Vivek
jbdavid
Reply #2 - Aug 3rd, 2006, 4:33am
There is DEFINITELY a difference between Verilog-A and Verilog-AMS..
Verilog-A is the ANALOG ONLY subset of the language.. hence its usefulness to the compact modelling community and analog designers..using only Spectre
jbdavid
