Apr 29th, 2024, 11:56am
Analog Mixed Signal Design Engineer Needed! (Read 33 times)
phoenix
Jul 06th, 2006, 2:43pm
Do you want to work with a design team whose signature is under several award-winning products? This is your chance to join us. We have multiple positions available for experienced Analog and Mixed-Signal IC Design Engineers. We are conveniently located in the Phoenix area.
Responsibilities cover the entire product development cycle including helping define the new product, determine architecture, and perform system level behavioral simulations, transistor level design and simulation, IC evaluation and ATE test development support for introduction.
Responsibilities include:
System and transistor-level design of analog circuit blocks such as Amplifiers, References, Comparators, Serializers/Deserializers, Clock and Data Recovery Circuits and corresponding High-speed interface logic, Fractional-N/S-D/Integer-N PLLs and PLL components like VCOs, PFDs, Dividers etc. These blocks will be used in high-speed interconnect, signal processing and data communications ICs designed for automotive displays/camera applications, cell phones, printers, basestations etc.
Job Requirement:
A minimum of 3 years' experience is required. MSEE or PhD is preferred.
Candidates must have demonstrated experience in designing mixed-signal circuits and taking an IC through design, layout, evaluation, and release to production.
Strong communications and interpersonal skills are required.
Candidates must be self-starters and motivated to excel
A demonstrated facility with schematic capture and circuit simulation (SPICE, Viewlogic, Cadence) tools is required.
Signal processing skills and facility with MATLAB/SIMULINK are a plus.
Ability to floor-plan and supervise layout, and strong knowledge of device physics required.
Backend experience (troubleshooting, probing, etc.) is a plus
Contract and Direct Hire Positions Available!!!
Compensation: $80,000 - $130,000
If this position is of interest to you, please send me a message and if possible your resume.  Thank you.
If this position is not of interest to you, is there anyone you could refer to us that might be interested in the position? We are offering a $500 referral bonus for any candidate you refer and we hire after they are on the job for 30 days.
