May 13th, 2024, 7:15pm
AMS (hierarchal view) help needed (Read 5721 times)
raftman
Aug 07th, 2006, 2:27pm
Ok, so I've been struggling the past week or so to run a mixed signal simulation using AMS.
I've gotten through the design prep stage fine - but now in the elaboration phase I'm encountering errors.  It seems to be the veriloga instances are not being resolved.
ncelab: *W,CUNOUN: Cannot find any unit under myLib.myCell:veriloga in the design libraries.
ncelab: *E,CUCFUN: instance 'I61' of the unit 'myCell' is unresolved in 'myLib.topCell:schematic'.
Can someone please help me figure out how to resolve these corretly?  I see other cells being resolved correctly "using config 5.x rules" - but I'm not sure what these are, or how I edit them.
Also, I have tried to create AMS netlists on 'check and save' via CIW->tools->AMS->options and selecting "Perform AMS checks", "Generate AMS netlist", and "Compile generated AMS netlist".   However, after check and save I get plenty of
"Info: No valid definition view found for library: "myLib" cell: "myCell".
       The views specified in the 'amsDefinitionViews' ams.env variable are:
       Netlisting will continue without processing the definition view..."
Can someone please clearly explain whay I need to change in ams.env exactly?
Your help is greatly appreciated!
Raftman
Aigneryu
Re: AMS (hierarchal view) help needed
Reply #1 - Aug 8th, 2006, 1:35pm
Did you use the template for the view list in the config view?
this messgae assumes you did not use proper config view setup
this message assume that your design does not elaborate
somestime caused by missing lib files
Currently I am working on the conversion of all my previous spectreVerilog designs to AMS, I also had some weird problems.
raftman
Reply #2 - Aug 8th, 2006, 1:42pm
Thanks, I ended up fixing the unresolved instances by copying over the default ams.env file from the installation directory.
However, I am having problems with the connect modules.  I found and installed the libraries (correctly I believe), but am getting the following error and warning.
ncelab: *W,CUCMCB (../SAR_cap_array/test_adc_ahdl/schematic/verilog.vams,91|36): Resolve connect module logic2elect binding through a search of the library which has the view
of connectrules unit, connectLib.logic2elect:module is taken.
sample_out ), .vrefpcontp( vrefpcontp[11:0] ), .dout( dout[11:0] ) );
ncelab: *E,CUVNCM (../SAR_cap_array/test_adc_ahdl/schematic/verilog.vams,91|57): No connection module found:Need an input port of discrete discipline logic, and an output port
of continuous discipline voltage.
I am confused because the warning (top) indicates that logic2elec was found, yet the error (bottom) complains about needing a module from "discrete/logic to continuous/voltage" -> which should be logic2elec correct?
Can you describe how you setup the connectLib (compilation, directory locations, elaborator, etc).
Many thanks!
Aigneryu
Reply #3 - Aug 8th, 2006, 5:02pm
You can try the tutoriaal files in your CDS_IC installation directories.
It is in INSTALLATION/tools/dfII/samples/tutorials/AMS
then check the document named Virtuoso AMS environment user Guide, chapter "quick-start tutorial "
I am still working on it to get understanding what are essentials in setting up an AMS simulation, since I origianlly used spectreverilog.
Hope it helps.
raftman
Reply #4 - Aug 9th, 2006, 11:03am
Thanks - I found the tutorial and was able to get through it.
Now my design elaborates without errors ( a few warnings
ncelab: *W,CUCMCB (../SAR_cap_array/test_adc_ahdl/schematic/verilog.vams,90|28): Resolve connect module logic2elect binding through a search of the library which h
as the view of connectrules unit, connectLib.logic2elect:module is taken.
reset ), .vpurgecontp( net470[0:11] ), .sample( sample_in ), .vpurgecontn(
but I think these are ok.
However, maybe not - in simulation the outputs of my functional blocks (imported verilog) do not behave correctly.  They do not show full logic levels.  I will try to isolate the problem buy any advice will be appreciated!!
Smiley
BTW, is it possible to see the full netlist (after connect modules are automatically added)?
