May 17th, 2024, 8:02am
Verilog A (Read 3003 times)
Jamz_will
Singapore
Verilog A
Aug 14th, 2006, 6:31pm
Can I simulate my spice netlist and verilog behavioral model using verilog -a simulator if they behave the same?
If its possible, can you give me an idea how?
Thanks.
Jamz_will
Re: Verilog A
Reply #1 - Aug 15th, 2006, 4:38am
Most if not all of the major analog simulators support Verilog-A.  You can either run two netlists (one Verilog-A, one transistor-level) and compare the output waveforms from two simulations, or you can try to merge the two netlists into one (eg, put "adder" and "adder_va" in one netlist, and hook up their inputs to the same voltage sources, or if you have current inputs, you probably need to duplicate them) and compare the outputs within one simulation.
Re: Verilog A
Reply #2 - Aug 15th, 2006, 8:38am
You cannot simulate Verilog code in a Verilog-A simulator. Verilog-A is a Verilog-like language suitable for describing analog circuitry. If you have Verilog code, you will need a Verilog-AMS simulator, which combines Verilog and Verilog-A. Verilog-AMS simulators allow one to combine SPICE netlists with Verilog code.
