jbdavid
Tools: Use an AMS simulator like Cadence's AMS-Designer, Mentor's Eldo or synopsis Discovery-AMS (I use AMS-Designer, cause that what I have experience with and licenses for (needs three Spectre Tokens))
Make a schematic TB in Virtuoso.. figure out what behaviors you need to check.. (phase lock, lock time, correct output frequency for PLL?) write Verilog-A models to check those parameters.. For the ADC you might be able to simply perform a logic (bitwise) XOR of the outputs from the circuit and behavioral model, for the DAC you could take the difference between the two outputs. I used an ADC as the example in my Tutorial on Verilog-AMS language given at BMAS a few years ago. so I have examples of an output comparsion block I did for the ADC there.. (Let me plug BMAS again, its coming around in just a couple of weeks Sept 14-15, REGISTER NOW!!- right after CICC (and CDNlive unfortunately the SAME time as CICC) - in Pleasant San Jose..
Jonathan
