May 5th, 2024, 9:20am
Behavioral Models of PLL, DAC and ADC (Read 3870 times)
Jamz_will
Singapore
Aug 14th, 2006, 7:21pm
I would like to check the behavioral models of PLL. DAC or ADC are doing the correct function.
How can i check this? Do i need also a testbench for this? What tools i need to use?
Thanks alot! Wink
Re: Behavioral Models of PLL, DAC and ADC
Reply #1 - Aug 20th, 2006, 3:37pm
I think the responses to your post http://www.designers-guide.org/Forum/YaBB.pl?num=1154423549 will answer this.
jbdavid
Reply #2 - Aug 29th, 2006, 10:51am
Tools: Use an AMS simulator like Cadence's AMS-Designer, Mentor's Eldo or synopsis Discovery-AMS (I use AMS-Designer, cause that what I have experience with and licenses for (needs three Spectre Tokens))
Make a schematic TB in Virtuoso..
figure out what behaviors you need to check.. (phase lock, lock time, correct output frequency for PLL?)
write Verilog-A models to check those parameters..
For the ADC you might be able to simply perform a logic (bitwise) XOR of the outputs from the circuit and behavioral model,
for the DAC you could take the difference between the two outputs.
I used an ADC as the example in my Tutorial on Verilog-AMS language given at BMAS a few years ago. so I have examples of an output comparsion block I did for the ADC there..
(Let me plug BMAS again, its coming around in just a couple of weeks Sept 14-15, REGISTER NOW!!- right after CICC (and CDNlive unfortunately the SAME time as CICC) - in Pleasant San Jose..
Jonathan
jbdavid
