Aug 23rd, 2024, 10:18am
over voltage protection (Read 3129 times)
ysc
Aug 14th, 2006, 7:48pm
Can some body give me ideas to design a circuit that takes an input voltage from 2.8v to 5.25 volts but limits the output to less than or equal to 4.0v. The current drawn is of concern too. any help is appreciated.
ACWWong
Oxford, UK
Re: over voltage protection
Reply #1 - Aug 15th, 2006, 2:28am
what is the power supply voltage ?
ysc
Reply #2 - Aug 15th, 2006, 6:04am
The power supply voltage can vary from 2.8v to 5.25v. The output of this circuit should be less than or equal to 4v. In other words this circuit does not do anything for input voltages less than 4.0v. when the input voltage crosses 4.0v  this limits the output voltage to 4.0v .
ACWWong
Oxford, UK
Reply #3 - Aug 15th, 2006, 6:52am
ysc wrote on Aug 15th, 2006, 6:04am:
I'm confused, as your last post contradicts your previous post...
anyway I think what you need is a regulated output supply of 4V. This means for supply voltages 4V to 5.5V you get a limited output at 4V max. For supply voltages 2.8V to 4V, the output is limited at the supply voltage.
You can design a low drop-out regulator using a banggap refence voltage and multplying it up with an oaamp and an output PMOs and resistive divider. Google voltage regulator or LDO for info.
I hope this answers what you want.
Reply #4 - Aug 15th, 2006, 9:20am
Agreed with the prior post - you want an LDO regulator.
A conventional voltage regulator architecture won't get it done.
http://www.national.com/pf/LP/LP3997.html
The above is one example, there are many more out there.
Take a look at the internal block diagram of the device to get the idea.
hope that helps,
Jerry
