I am struggling with a simulation of a circuit including BSIM43 model transistors in Spectre.
I suspect that my problem could be caused to AS and AD parameters being set or not (i.e. default hanling applies - for calculating ASeff, Adeff).
It would be very helpful if I could see the calculated values of ADeff and ASeff, however I cannot find where they would be output.
I have set
outputParameter info what=all where=rawfile
but I only get: "leff, rgbi, weff".
Also I tried to set 'element info' to 'all' - I get a lot of parameters but not adeff nor aseff.
After reading Spectre manual for 2 days now - I am stuck and running out of options to try.
So, perhaps you guys and gals had run into similar problem before :
Is it possible to see calculated ADeff and ASeff? If yes, where to look for/which flag to set to get it? Any suggestion would be very much appreciated
Ema
